hey, i have been looking around trying to see if it was possible to use a t-56 tranny, EASILY. namely because you can get a used unit for half the price of a getrag...
so here it goes:
1:get a steel bellhousing, have the bolt pattern of the 2jz drilled into it (read below for my idea on this),
2: use STOCK na flywheel or tt fly
3: use performance clutch from a 2jz (STOCK part replacements)
4: use a clutch from a t-56 CAMARO (for correct splines and input diameter)
5: t-56 from camaro/trans-am/etc (maybe 03 cobra or viper....namely chevy t-56 because older=cheaper)
6: obviously custom driveshaft
i have found one of the 2jz clutc discs is 250 mm (9.8 inch)
http://replacement.car-stuff.com/parts/carstuff/wizard.jsp?year=1993&make=TO&model=SUP--008&category=I&part=Clutch%20Kit&returnurl=null&dp=true&showdc=true#top
the camaro discs range from 9 11/16 up to 12 inches
http://replacement.car-stuff.com/parts/carstuff/wizard.jsp?year=1999&make=CV&model=CAMA-Z28-002&category=I&part=Clutch%20Kit&returnurl=null&dp=true&showdc=true#top
i also read somewhere about a person having a cluth disc machined down.... so i thought that there HAS to be a combo of the 2jz fly/pressure plates and a disc from the chevy line. they have the same thickness of disc, and if the diameters were the same (machined the disc and/or fly), then it might work...
the t-56 shifter arm is 26.5 inches from bellhousing and the w-58 that goes in the lexus is 26 7/8. so it would fit there without adjustment (.25 inch!!)
things of concern and potential fixes:
1: when clutch is in the pressure plate, the splines dont reach the input shaft or are too long
SOLUTION: too short, you could maybe put a small spacer on the crank....like i mean 1/8 MAX. with ARP studs, this shouldnt effect it TOO badly....?? :1poke: too long, the tranny could be spaced from the housing, again, probabaly not MUCH, but these MAY be ok if the difference is SMALL!!
2: bellhousing hits body.
SOLUTION: hammer
3: getting bellhousing that has 2jz bolt holes drilled
SOLUTION: ross machine makes an adaptor for the th400 tranny to mate to a 2jz. steel bellhousings that mate to a t-56 can be made to fit a th-400 motor bolt pattern. SO.... if a few people wanted to do this, the adaptor from ross is like 350 split 5 ways isnt so bad, then sell it after you make your marks (wont damage or dertroy unit after all).
what do you think??
so here it goes:
SOLUTION: hammer
what do you think??
