My power steering has been leaking for about a week now, after filling up the power steering fluid with ATF I started my car and had someone turn the wheel back and fourth while raising the rpm's. After about 30 seconds of doing this (all the while the pump was making that horribile whining noise) I watched as the fluid expolded out from under the cap, it was leaking everywhere. Its almost as if there is a block in the system causing the pressure to push the fluid out around the cap, or could this just be a bad cap?
