1 - 3 of 3 Posts
DitchByTheSideOfTheRoad
Ok first off I would search, but I can't so I am not...
What to use on out car's power streering. Manual say Dexron II(I spell that right?)
The Dexron III is out and I couldn't locate any of the II...so in went the III...(after Toyota shop said normal PS fluid is what was required...lamers...good thing I checked my manual before I added it)
Now I need to do a complete flush of the PS system anyway(coming up on 120k miles)...what should I add to it? Dexron III Synthetic? or just the normal stuff...
TiA
Brent
Oh just for a quick reminder...since I am changing fluids...what would the general consensus be for the remaining fluids? Trans fluid is still Toyota only right???
Use T4 tranny fluid (toyota) not very cheap but works good. It will kep things clean and lubricate well. Buy some extended hose adn flush the system into a bucket first. I was shocked how black the fluid was when it came out.
Hope that helps.
Ben........
I use Redline Dexron 3 ATF
And in the tranny use only V160 Toyota stuff
And in the Differential i have been using Redline shockproof
1 - 3 of 3 Posts
