1 - 9 of 9 Posts
Power Steering COOLER
Does anyone know where to get one of these and how much? I need one ASAP!!! If you could also post pics where you put it would be most helpful. thanks all for responding that do.
-SUPRAT
1994 Toyota Supra Power Steering Pump PWR $275 K217 Diamond Auto Parts - QRP Partner 1-800-236-7731 E-mail USA-WI
1994 Toyota Supra Power Steering Pump R134A $250 009040 Merasian Auto Parts 1-800-695-1021 E-mail USA-MI
1994 Toyota Supra Power Steering Pump WB,3.0TB $175 BM137 King George Auto Parts 1-800-847-4547 E-mail USA-VA
1994 Toyota Supra Power Steering Pump WB,3.0TB $175 8C7820 King George Auto Parts 1-800-847-4547 E-mail USA-VA
1996 Toyota Supra Power Steering Pump turbo- $150.03 99-099 Mazda-Toyota Auto Recycling 1-800-800-4570 E-mail USA-OR
1994 Toyota Supra Power Steering Pump w/turbo- $150 960860 Northwest Imports, Inc. 1-316-522-4961 E-mail USA-KS
1993 Toyota Supra Power Steering Pump (frm 5/93), w/turbo- $Call I2492 Brims Imports Auto 1-419-675-1099 E-mail USA-OH
1993 Toyota Supra Power Steering Pump JZA80 (frm 5/93), w/turbo- $Call K2871 Brims Imports Auto 1-419-675-1099 E-mail USA-OH
1994 Toyota Supra Power Steering Pump 3.0,6SP $Call PA0116 LKQ - B and D Auto Recyclers 1-800-321-3209 E-mail USA-AL
1994 Toyota Supra Power Steering Pump w/turbo- $Call H3077 Brims Imports Auto 1-419-675-1099 E-mail USA-OH
1994 Toyota Supra Power Steering Pump w/turbo- $Call K0727 Brims Imports Auto 1-419-675-1099 E-mail USA-OH
1996 Toyota Supra Power Steering Pump w/turbo- $Call I0705 Brims Imports Auto 1-419-675-1099 E-mail USA-OH
Cheap and Easy!
You want a power steering COOLER, right?
Get an automatic trans cooler from Pep Boys for $45 and install it in front of the radiator.
Or, to keep the reservoir from boiling over and squirting everywhere on the track, only fill the reservoir to the min line. It helps to use Mobil 1 synthetic ATF or Redline synthetic ATF. They have Toyota's recommended Mercon rating, and they don't gum up and cause varnish and sludge like conventional fluids do under the extra heat of track use.
Re: Cheap and Easy!
I wouldn't put anything in front of the radiator if possible (which it is). You might trade one issue for another.
Howdy Folks -
I bought a little B&M radiator/cooler - I believe intended for auto trannies - had the guys run it inline on the PS fluid line. I'll have to snap some pics to show you where they mounted it.
Not a bad solution for a couple of hours labor and a $65 part.
FYI, I'm running an HKS Type-R FMIC, a Greddy 16row oil cooler, and a Fluidyne radiator, all semi-sandwiched in the front, along with the ac condensor - I haven't had any extreme overheating problems, _but_ last summer (I'm in N. FL, gets pretty warm) - I noticed my AC did not pull as cool as it should - probably because it's having to circulate air through that giant layer of radiators/coolers/etc.
SF.com Member #0000000023
Where'd you get this info from? might make a good future reference.
Thanks,
Mike
1 - 9 of 9 Posts
