1 - 4 of 4 Posts
Found E85 NOT in NJ!
Well after getting a DaveH intake manifold, I had to replace the fitting on the oil pump with a TT fitting.
My question is the NA and TT power steering pumps the same?
Reason being when I was looking at the TSRM, they have two diagrams.
Now what exactly are those hoses used for in those red circles? What should I hook up in my setup? Should I connect them to a vacuum source? To a clean air supply?
Alan
Discussion Starter #2
After further inspection of the TSRM, I found out that one line is connected to any air source and the other is connected to vacuum.
Does the PS pump need a vacuum connection? I am just trying to double check things before starting.
2JZ yes shit
Both use the same pump. TT has the reservoir located away to make room for the tb and ic piping. Bottom (circled red) is the feed, top is the return back to the reservoir.
1 - 4 of 4 Posts
