It would never seal right going into the pump, at the banjo bolt. I never could figure out why. Replaced all the banjo bolts with new 2jz ones,tried the 1jz ones again,new gaskets,even swapped pumps. Had the hose replaced under parts warrenty and after all that, it leaked just the same, it also never seemed to bleed all the air out. I'll try and get some pics soon, it's only like a 1 foot section of hose.I didn't bother routing it under the pan, already have the other/better cooler. I used a 3 way "T" fitting and a fuel injection adapter from earls to fit the idle up valve in, came out nice. I had hose, but all the fittings I think were under 100.00 and it looks way better and doesn't leak a drop. I didn't even use the special PS hose, just regular -6 I had left over. I'll try and snap some pics tonight or tomorrow....
