1 - 20 of 21 Posts
· Banned
shit i heard some news it doesnt either. Im screwed. What about emanage ult? I need a bandaid to work some 720cc injectors or maybe just stock 550cc supras til i can switch to a gm auto
· Banned
crappppp i guess ill just go SAFC2 for a bandaid.. whats the biggest injector that i can use with it?
I dunno if my budget will allow me to junkyard a TH700R4, get the Dave H adapter kit, and get a driveshaft made, aftermarket shifter, and STILL get a powerFC. Ill have to see how cheap i can find a stock 700r4 and torque converter for...
· Banned
I kinda missed that detail. I woulda figured it worked since like 90% of Soarers are auto tranny!!!!!!!!!!!
I mean i guess i could do something really GHETTO! Run both ECUS! Run the PowerFC to all the normal plug and play stuff, and run the tranny wires and split the speed signal to the stock ecu only (with power and ground).
· Not so boring anymore
i would think the powerfc could run an auto trans.. any documentation saying it cant? maybe contact apexi?
· Banned
This puts a big hurting on my plans and future plans and having to buy things twice (fuel system). Ill call them in about 30 mins. It seems crazy they would sell a plug and play ECU for the Soarer that does not work with the auto when 99% of them are automatic.
· Banned
Discussion Starter · #12 ·
I called Apexi, 1JZ power FC does not control the transmission.
I ordered the Latent Solutions transmission controller and Apexi PowerFC.
Problem solved!!!1
Problem solved!!!1[/QUO
I tried sending you a pm but your inbox says its full
· HMOOB VWJ NYOB MINNESOTA
Marotta1 said:
Hey, by the way, do you know how high the redline can be set with a Power FC?
If you're using the commander then it max out 8999. If you're using the datalogit then (I think) it is 12000.
· Banned
Discussion Starter · #18 ·
Rising_sun said:
The Emanage Ultimate can control the 1JZ auto transmission
Its ok, i got the SupraStick V4 (flucking awesome!!!), and the Power FC. I'll be installing them when i install everything else. Piggy backs cause more problems then results. My car is going to look like james bonds car with the V4 LCD screen mounted in my dash, and the power FC controller, plus gauges, etc etc.. and i still do not have a working radio!
1 - 20 of 21 Posts
