1 - 8 of 8 Posts
Hey guys,
Just got the car tuned a couple of weeks ago. I was very pleased with the results
Pump gas 94 octane, Going corn next year numbers will definitely go up.
26 psi
Dyno jet
723 HP / 570 FT/TQ
here is some info on the build,
2jzgte, Non vvti
Block:
Eagle rods
CP Pistons- 9:1 compression
ACL bearings
ARP main rod Bolts
Upgraded wrist pins
Titan Oil Pump
Titan Motorsports Crank Damper Pulley V2
ETC...
Head:
Stock head
Tomei 264 cams
Tomei Cam gears
ARP head Bolts
Turbo:
Precision Gen 2 6870 - 1.0 divided T4
Precision 46mm wastegate
Sound performance T4 Divided manifold
Engine management:
AEM V2 ECU
Cams at this point will have to be upgraded as they were a good fit for my older setup(gt40r).
iSPOOL
Great numbers. How much are you expecting with E85 and a cam swap? Which cams also?
Thanks Shady,
I am shooting for 850 Range. I have everything required to max the turbo out, might use E98 next summer.
Cams will be BC276 Billet.
iSPOOL
Awesome stuff. I am stuck between this turbo and the 6766. I wanted 700-750rwhp after manual swap.
Any plans on doing springs and retainers upgrade to increase the RPM range?
"Any plans on doing springs and retainers upgrade to increase the RPM range? "
Yup, do it once and get it over with. Right now i'm set for 7600 RPM
6766 perfectly capable of 700 range.
throw a QSV and VVTI on there for more spool!!!
  • Like
Reactions: JOutterbridge
Discussion Starter #8
Thanks guys. I found a place that sells 105 from the pump, might go back and extend the tune for 105.
1 - 8 of 8 Posts
