1 - 9 of 9 Posts
· Not ur jizz, not ur bizz
do you have your charcoal canister still connected?
It's supposed to vent into your throttle body after the engine warms up. Do you have the lines connected from the charcoal canister to the thermostat housing, and from there on to the throttle body?
If so, run your engine until it's hot, then pull off the line at the charcoal canister and see if you can blow through it. If you cannot, then your switch on the thermostat housing is toasted.
· Acceleration
Correct. Make sure u get a 2 way and not a 1 way. I bought a 1 way and they wouldn't let me get a refund when I found out they screwed me. U can also drill a hole in ur stock gas cap if u don't wanna buy a new one. U just pop it apart and drill a hole in one of the pieces (I can't remember which.. bottom part I think) diagonally and ur good to go.
1 - 9 of 9 Posts
