so i finally did a pressure test because my car had mad boost leak. i was leaking out of both sides of intercooler and a bunch of vac lines. it seems those expensive t-bolt clamps were too big and the cheap clamps tightened better. anyway, after i fixed all those i ran the car at 30 psi with the compressor to similate the car at high boost. injector #1 popped out completely and the rest were all very loose. if i experienced this while driving my engine would have blown most likely. how can i fix this problem. i thought the injectors should have had a perfect fit but they seem loose.
thanks
Ray
thanks
Ray
