1 - 8 of 8 Posts
Heres what I need for my 89 turbo.
-02 sensor gasket
-turbo-> turbo elbow gasket
-intake manifold-> TB gasket
-3000 pipe -> BOV and accordian hose -> BOV hoses
-all pieces to the battery hold down clamp
-All weatherstripping/moulding that goes on the sides of the targa above the windows, all I have is the new panel. I need them in med grey.
Thanks!
Super Moderator
-02 sensor gasket
89466-20020-83 LIST 7.08 COST 5.23
17279-42010 LIST 45.18 COST 33.41
22271-42040 LIST 4.49 COST 3.32
-3000 pipe -> BOV
and accordian hose
17882-42012 LIST 45.18 COST 33.41
-> BOV hoses
17342-42040 LIST 22.69 COST 16.92
17341-42070 LIST 22.89 COST 16.92
90445-10022 LIST 10.75 COST 7.95
74404-14310 LIST 13.63 COST 10.16 BRKT
74451-22030 LIST 1.74 COST 1.29 J BOLT
90179-06206 LIST .91 COST .68 NUT
91651-G0614 LIST .66 COST .49 BOLT
62384-14052 LIST 26.69 COST 20.15 W/STRIP
62383-14052 LIST 26.69 COST 20.15 W/STRIP
63217-14011-03 LIST 102.74 COST 75.98 MLD
63218-14011-03 LIST 102.74 COST 75.98 MLD
Thanks!
I need more info on the item above in question.
Okay, I didn't know a real good way to say what I meant, so here's a picture, and I'll see if I can do better. I don't need the accordian hose itself. The stock bypass valve is pictured, I need the hoses that run from it to that aluminum intake pipe, and the accordian hose. Hope that helps.
Super Moderator
these are the 3 hose that attatch to the stock BOV
Discussion Starter #5 (Edited)
Alright, thank! One more question actually though. Where can I get the SSTs like belt tension guages, pulley/gear pullers etc? Are they available through a dealer or do I need to call somewhere else?
Also can I get:
Thermostat
thermostat housing gasket
all major coolant hoses (arterys, if you will)
Super Moderator
Engine Small Water Hoses:
16267-42010 List 19.01 Cost 14.11
16282-42010 List 15.05 Cost 11.13
16283-42010 List 16.21 Cost 11.99
16284-42011 List 13.73 Cost 10.25
16285-42010 List 7.54 Cost 5.63
Radiator Hoses:
16571-42010 List 19.98 Cost 14.77
16572-42010 List 41.87 Cost 31.03
Efi Water Hoses:
16261-42010 List 16.29 Cost 12.10
16264-42040 List 27.47 Cost 18.29
Heater Hoses:
87245-1b251 List 35.55 Cost 26.29
87245-1b220 List 18.52 Cost 13.83
87245-1b262 List 26.84 Cost 19.84
Thermostat/gasket
16341-35010 List 2.00 Cost 1.48
90916-03078 List 12.41 Cost 9.18
Alright, one more thing and I swear this will be the last. :) I need tail light gaskets, and also the price of a new tail light incase I break mine trying to clean it. Something I don't think are available any more but it would be great if I could get them... OEM "Supra" floor mats for my 89 in med grey. Last I heard they weren't making them any more but I figured I would just triple check.Thanks!
Super Moderator
81554-14580 Gasket,rr List 17.44 Cost 12.90
81564-14610 Gasket,lr List 17.18 Cost 12.82
Tail Lights List 178.00 Cost 131.00 Ea
1 - 8 of 8 Posts
