im doing a six speed swap and all i have is a rps triple carbon and the tranny. i need everything from the tail shaft to the clutch master cylinder. im assuming the parts needed are as followed.
-tripod/shifter assembly
-Trans cross member/mount
-slave cylinder/trs ss clutch line
-shifter fork and necessary bearings
-trans tunnel
-tripod
-clutch master cylinder/pedal assembly
-brake pedal (ill keep the auto gass pedal)
-and i also need new bolts that bolt trans to the motor
Im sure its already been quoted but i want to be sure i get everthing i need. Thanks for your help!!
