IG UPDATES @ #BADMTHRFUKR
I need all the hardware (Bolts,nuts..ect.) that goes to the timing tensiner and the shock. The only pieces I have is the "Bar" that fits to the tensinor and the "Shock". ..I dont have any bolts,nuts.ect. What would the price be for these parts???? THANKS!!!
The timing belt tensioner is externally mounted to the oil pump by two bolts.
There is no " shock ".
Are you also looking for the timing belt idler pulley???
That might be it!!! The shock thing I was talking about is beside the harmonic balancer on the right towards the drivers side.the shock thing is connected to a little bar that connects to this round part that has two bolt holes which i thought was the tensinor??? The round piece is right above a pulley that has tension on a belt. I hope this helps..Sorry for the poor description.!!!
16620-46070 Tensioner List 208.57 Cost 156.74
16621-46010 Bracket, List 42.81 Cost 32.18
16622-46010 Arm, List 20.52 Cost 15.43
16602-46010 Absorber List 66.59 Cost 50.04
91511-g0845 Bolt, List 1.00 Cost .75 Ea X 2
90901-16001 Bolt, List 2.26 Cost 1.70
90179-08171 Nut List 0.97 Cost 73 Ea X 2
90116-08348 Bolt, List 0.89 Cost 66 Ea X 2
90080-17242 Nut, List 1.46 Cost 110 Ea X 2
Thanks Curt!!!! Once again ..Your the Man!!!
