1 - 4 of 4 Posts
V160 Rebuild Kit/Gear Oil Change
First disassemble , then make up your parts list . Most rebuilds run in the 900-1500 range for parts only.
E-mail me your list and I'll send back a quote with current parts pricing. This list below is from last year and the prices are up approx 10%
90069-10001 BEARING LIST 57.87 COST 43.49
90069-10010 BEARING LIST 25.95 COST 19.50
90069-10007 BEARING LIST 22.38 COST 16.81
90069-10003 BEARING LIST 55.24 COST 41.51
90069-10018 BEARING LIST 34.78 COST 26.14
90069-10005 BEARING LIST 49.99 COST 37.56
90069-10008 BEARING LIST 43.58 COST 32.75 EA X 3
90069-10019 BEARING LIST 34.78 COST 26.14
90069-10020 BEARING LIST 34.78 COST 26.14
90069-10014 BEARING LIST 37.87 COST 28.46 EA X 2
90069-10004 BEARING LIST 76.19 COST 57.26
33382-0W011 RING, SYN LIST 59.36 COST 44.61 EA X 4
33387-0W020 RING, SYN LIST 67.42 COST 50.66 X 1
33376-0W010 RING, SYN LIST 54.02 COST 40.59 EA X 4
33373-0W010 RING, SYN LIST 29.84 COST 22.43 EA X 2
33372-0W010 RING, SYN LIST 29.84 COST 22.43 EA X 2
33369-0W010 RING, SYN LIST 36.90 COST 27.73 EA X 2
33360-0W011 HUB ASSY, 1 LIST 82.17 COST 61.75
33370-0W010 HUB ASSY, 2 LIST 82.17 COST 61.75
33380-0W010 HUB ASSY,3 LIST 98.60 COST 74.10
33352-0W020 HUB,ASSY, 4 LIST 96.57 COST 72.58
33032-0W030 GEAR 1ST LIST 171.43 COST 128.83
33033-0W050 GEAR 2ND LIST 171.43 COST 128.83
33034-0W050 GEAR 3RD LIST 152.39 COST 114.53
33035-0W010 GEAR 4TH LIST 152.39 COST 114.53
33428-0W030 GEAR, 5TH LIST 178.42 COST 134.09
33429-0W010 GEAR, 6TH LIST 188.14 COST 141.39
33421-0W060 GEAR, COUNTER LIST 254.84 COST 191.51
33461-0W030 GEAR, REVERSE LIST 114.29 COST 85.89
33037-0W010 GEAR 6TH SUB LIST 295.46 COST 222.04
33301-0W040 SHAFT INPUT LIST 198.51 COST 149.19
33230-0w010 #1 Shift Fork List 83.74 Cost 61.92
33240-0w010 #2 Shift Fork List 71.08 Cost 52.77
33250-0w020 Selector Fork Assy List 43.70 Cost 32.31
33260-0w010 #4/#5 Shift Fork List 263.93 Cost 195.16
08885-01306 V160 Oil Qt List 54.00 Cost 40.00
90069-08001 Frt Inner Seal List 19.75 Cost 15.36
90080-31031 Frt Outer Seal List 11.58 Cost 8.56
90080-31029 Rear Seal List 19.48 Cost 14.40
90080-31032 Shift Shaft Seal List 6.03 Cost 4.46
__________________
2JZ-GTE
*Piston Rings
*Full Timing Serivce
*Full Engine Gasket Set
15100-46052 OIL PUMP LIST 226.67 COST 170.00
04111-46094 FULL GASKET KIT LIST 480.77 COST 365.00
[includes valve stem seals and everything else you'll need]
00295-00103 FIPG PAN SEALER LIST 13.82 COST 10.44 EA X 3
90915-YZZD3 OIL FILTER V8 USA LIST 5.41 COST 3.96
00272-1LLAC-01 ANTIFREEZE RED LIST 25.39 COST 19.38 EA X 2
15710-46020 OIL COOLER LIST 610.64 COST 465.00
[MANDATORY IF YOUR MOTOR HAD ANY INTERNAL DAMAGE]
15670-46070 BRACKET OIL FILTER LIST 96.20 COST 73.44 [ FROM NA MODEL TO ELIMINATE STOCK TT OIL COOLER IF YOUR GOING TO USE AN AFTERMARKET ONE]
16100-49846 WATERPUMP LIST 166.70 COST 125.00
13505-46041 T/BELT IDLER LIST 88.14 COST 67.30
13568-49036 T/BELT LIST 34.68 COST 26.43
13540-46030 T/BELT TENSIONER LIST 74.94 COST 57.21
13011-46051 TT RING SET LIST 237.55 COST 180.00 [ std only]
13101-46091 TT PISTON LIST 80.34 COST 60.00 EA X 6 [ std only]
13201-46040 TT CONNECTION ROD LIST 88.63 COST 65.00 EA X 6
13041-46013-XX ROD BEARINGS LIST 15.67 COST 11.96 EA X 6
11071-46020-XX MAIN BEARING #1 LIST 25.83 COST 19.72
11701-46020-XX MAIN BEARING #2-#7 LIST 27.90 COST 21.30 EA X 6
11011-46030 THRUST WASHER SET LIST 40.95 COST 31.27
1 - 4 of 4 Posts
