1 - 10 of 10 Posts
OG SF Member #603
Curt,
Can I get some quotes for the following shipped to 21014?
front bumper, '97-'98 style
'97-'98 headlights and turn signals and whatever harness, etc I need to do a swap into a '93
front wiper arms
passenger airbag cover
Also, I'm doing a NA-->TT swap and I was wondering if there is anything in the engine bay that should be replaced to make the swap easier while I have the motor out? Harness, fuse box, etc? I already have a TT ecu. Would you recommend a TT fuel pump ecu?
Thanks again.
Scott
Super Moderator
73970-14030-c0 Air Bag Rh List 752.73 Cost 556.77
Adapter Wire 19.50
81111-1B241 RH head lamp LIST 485.37 COST 350.00
81151-1B241 LH head lamp LIST 485.37 COST 350.00
52119-14921 COVER,FRT BUMPER LIST 276.47 COST 204.12
81510-80086 LAMP ASSY RF LIST 72.26 COST 53.43
81520-80086 LAMP ASSY LF LIST 72.26 COST 53.43
81515-14390 HARNESS 21.433 COST 17.33
85211-14310 ARM, RF LIST 59.79 COST 44.21
85221-14310 ARM, LF LIST 49.74 COSTY 39.79
OG SF Member #603
Curt,
Is the airbag pass. cover sold separetely from the airbag? I only need the cover.
Thanks.
OG SF Member #603
Curt,
Next up....while swapping the NA auto rear diff w/ a TT auto rear diff, I noticed I'm missing the right rubber(I think the left one is rubber) support that the rear of the rear diff bolts into. I'm also missing whatever bolt(s) that go there. BTW, the right and left are if you're looking from the back of the car. How much for the missing parts? Let me know if I need to be more specific.
Thanks again.
OG SF Member #603
Have a couple more things to add to the list.
TRD engine mounts and whatever else is needed to bolt engine in. These are for a '93.5 NA chassis that I'm mounting a '94 TT motor, if it helps.
All new bolts for front and rear sway bars.
And I think my drivers side parking brake is bad, how much to replace?
Also, how would you like this ordered? Over the phone using part #'s or thru here or a website?
Thanks again.
Scott
Super Moderator
12360-JA800 TRD MOUNT LIST 128.80 COST 113.16 [ out of stock till early next month]
What bolts do you need for the sway bars?? Bracket to frame or Links to control arms?
Parking brake?? Shoes?? Cables??? etc. You need to be more specific.
OG SF Member #603
Discussion Starter #9
Curt,
All the bolts. The four that connect the bar to the body in the middle and the 2 outer bolts on each side that connect the link to the bar and the link to the control arm.
Sorry on the parking brake, I thought it might be a full replacement. 1 of the springs on the parking brake has come forward and is hitting the hub....so whatever I need to fix that?
Thanks again.
Scott
Super Moderator
90119-08A86 BOLT, FRT SB BRACKET LIST 0.74 COST 0.55 EA X 4
90179-10054 NUT SB END LINKS LIST 0.74 COST 0.55 EA X 8
90119-08588 BOLT, REAR SB BRACKET LIST 1.00 COST 0.74 EA X 4
47447-50010 Pin List 1.49 Cost 1.09 X 2
47447-30020 Pin List 1.49 Cost 1.09 X 2
47449-30030 Cup List 1.63 Cost 1.21 X 4
47449-40010 Cup List 2.34 Cost 1.73 X 4
90501-16118 Spring List 1.00 Cost .74 X 2
90501-16053 Spring List 1.57 Cost 1.17 X 2
90506-12051 Spring List 2.17 Cost 1.61 X 2
90905-a6001 Spring List 3.43 Cost 2.53 X 4
90504-14002 Spring List 4.40 Cost 3.26 X 2
1 - 10 of 10 Posts
