1 - 20 of 25 Posts
OG SF Member #603
Curt,
How much is a NA auto rear diff, pumpkin and internals? Can a TRD LSD(auto) be installed in the pumpkin?
I also need the 2 V springs for the front brake pads. The connect the 2 pads. Not sure if they're even necessary, but I'm missing a set on one of my calipers.
Scott
41110-14881 NA AUTO LSD DIFF ASSY LIST 2192.84 COST 1852.45
The TRD LSD UNIT is only for NA 5 speed / TT auto / TT 6 speed.
47743-24020 SPRING, LIST 3.34 COST 2.47 EA
OG SF Member #603
Curt,
Need a couple more prices to ad to my list.
Front and rear end links or whatever connects the sway bars to the chassis. It's a NA chassis, but I'm upgrading to TT sways if it makes a difference.
Also, on my previous post. Is there a difference btw the rear diff pumpkins? I know you said there's no TRD LSD for the NA auto, but I'm interested in knowing if I can swap the TRD auto LSD into a previously NA auto rear diff and then connect it to TT axles/ds?
Thanks again.
Scott
48820-24010 LINK ASSY frt list 64.08 cost 47.38 ea x 2
48830-14050/48840-14030 LINK ASSY REAR LIST 45.84 COST 33.90 EA X 2
I cannot answer your questions about the interchanagability on these.
OG SF Member #603
Couple more parts needed....
nuts/washers or whatever connects to the TT engine mounts?
OG SF Member #603
Curt,
More parts...
Whatever brackets/bolts/nuts/washers needed to attach radiator and a/c condenser to body.
I'm sending an order via email. Please include the above parts in the order, but also post them so I can get an idea of what's needed.
Thanks.
Scott
OG SF Member #603
Curt,
I have a question about 2 parts in my order.
53510-14240 LOCK ASSY RH LIST 61.73 COST 45.65
53510-14250 LOCK ASSY LH LIST 58.42 COST 45.65
What are these? Are they the 2 side latches on the body or the hooks on the hood? Either case, I have both of these. If not, let me know so I can keep them in the order.
Thanks.
Scott
OG SF Member #603
One more question....
Is there any difference between the NA and TT a/c system. Same for radiator/fan assembly(shroud, fan, fan clutch, etc).
Thanks again.
Scott
OG SF Member #603
Discussion Starter · #11 ·
fledis said:
Curt,
Thanks.
Scott
Any word?
fledis said:
Curt,
More parts...
Thanks.
Scott
Per your response....
Brackets/bolts/nuts/washers needed to attach TT radiator and a/c condenser?
Thanks.
OG SF Member #603
Discussion Starter · #12 ·
Curt,
I emailed you an order for some parts, but forgot a "Subject". Let me know if it doesn't get to ya.
Thanks.
Scott
OG SF Member #603
Discussion Starter · #14 ·
Can you give me a quote for these parts so I can add them to the order?
Thanks.
Scott
Condensor
88467-32020 Bushing List 6.10 Cost 4.67 Ea X 2
90080-11163 Bolt List 0.63 Cost 0.49 Ea X 2
Radiator
90480-40012 Grommet List 8.55 Cost 6.32 Ea X 2
16505-46040 Support List 7.46 Cost 5.51 Ea X 2
OG SF Member #603
Discussion Starter · #16 ·
Curt Aigner said:
Condensor
Radiator
Curt,
Go ahead and add these to my order, if you haven't already.
Thanks.
Scott
What is necessary to replace my open diff on my NA 5spd to a TRD unit. Carrier bearings? if so how much total including the TRD LSD to do the complete swap?
thanks in advance :)
kevin
1 - 20 of 25 Posts
