Hi guys,
we got our Profec installed nicely yesterday, so far no problem. The problem begun as we tried to set it up. When we set a boost level and try to make it learn in the automatic mode, then it goes way past the set boost level into fuel cut. After a few more runs then it only will do stock pressure or even less.
Today we tried it again, to see if we could get it working properly, but the same thing happened. Then auto p. symbol in the top right corner starts blinking, so it says it is in the second step of the learning function, but then it only gives us stock pressure or less, and that symbol just won't stop blinking. Then it once pushed in the overtake boost, what worked for some reason. then we did another pull and tried to do the overtake setting but it wouldn't do it again, it just stays at stock pressure. The instructions say it might not learn properly, if the exhaust pressure it too high. Our supra still has both cats in it, might that be a problem? How many pulls does it normally take for the profec e-01 to learn in automatic mode?
Thanks a lot
Mark
Thanks a lot
Mark
