1 - 11 of 11 Posts
Is it turbo??
I normally can boost to 7.5 psi but the highest i can see now is 4-5 psi... and as i drive at wot it sometimes goes down to 2 psi. i made a boost leak tester and found and sealed up all my boost leaks through my couplers. still low boost!! can a vacuum leak some where in the vacuum system cause me not to boost above 3-4 psi?? any suggestions please!!
What BoV do you have?
I have a friend that had the same problem on his mk3 supra turns out the the bov didn't close all the way and it was leaking very little.Also check your intercooler, exhaust,wastegate.
Is it turbo??
well i have a "s" pipe with a greddy type s and a "s" pipe with a hks ssqv. and they dont leak so i dont think its that.. im begining to think its the intercooler but is there anyway to check and see if that would be the problem??
Is it turbo??
Discussion Starter #6
i made a thing where i can pressurize my system... but i found the problem... :( it was the intercooler!! i put the small one back on and there was all my boost!!
Do you have a bigger intercooler?
Bigger intercooler need more air in the intercooler, so if you did replace it with a bigger one, psi should have drop
Is it turbo??
Discussion Starter #9
no it wasnt leaking. we pressurized my system to 10 psi and had no leaks. and it is a better intercooler but not very much bigger. i dont think is good to go from 7.5 psi to 3-4 psi. the only thing i can think of is it wasnt built correctly and is less effiecient..
Is it turbo??
Discussion Starter #10
well i talked to my friend and he said to take the vacuum line off that goes from the compressor to the wastegate off and run it to a different source on the intake manifold and just plug up the nipple on the compressor. im gonna try that and see what happens...
Is it turbo??
Discussion Starter #11
problem fixed!! i did was i said ^^^ there! But i have a little more lag now. typical in a bigger intercooler
1 - 11 of 11 Posts
