1 - 1 of 1 Posts
Product Release: BTI 52mm CAN Gauge with ProEFI Integration
NEW: 52mm CAN Bus Gauge with Professional EFI Systems Inc. integration
BTI Gauges 52mm CAN gauge with ProEFI integration. This gauge is capable of displaying parameters on 12 programmable screens. View telemetry data exactly as the ECU sees them with a fairly simple 4 wire termination. There are compound parameter screens that include a peak hold function for boost. wheel slip, and knock energy. Displays single or multiple channels and is completely configurable to your needs/desires!
Parameters available on ProEFI ECUs:
  • Lambda 1 / AFR 1
  • Lambda2 / AFR 2
  • Lambda Average (Lambda 1 + Lambda2 divided by 2)
  • AFR Average (AFR1 + AFR2 divided by 2)
  • Lambda Target
  • AFR Target
  • Manifold Air Pressure (Kpa or psi)
  • Fuel Pressure (psi)
  • Oil Pressure (psi)
  • Intake Air Temperature (Celsius or Fahrenheit)
  • Coolant Temperature (Celsius or Fahrenheit)
  • Engine Speed (RPM) / Rev Limit
  • Ignition Timing
  • Battery Volts
  • Throttle percentage
  • Engine Torque
  • Horsepower
  • Ethanol Content (%)
  • Vehicle Speed (MPH)
  • Calculated Gear
  • Driven / Non-Driven Wheel speed
  • Differential Wheel Speed / Differential Wheel Speed Allowed
  • TCS Spark
  • Mas g/sec (MAF airflow)
  • EGT 1 & 2
  • Exhaust Back Pressure
  • Nitrous Pressure (1-4)
  • Injector 1 Pulse width (ms)
  • Injector Lambda Feedback
  • Injector Duty Cycle (%)
  • Air Box Temp (Celsius or Fahrenheit)
  • Oil Temperature (Celsius or Fahrenheit)
  • Mode Switch
  • Transmission Temperature (Celsius or Fahrenheit)
  • AT Shifter Position
  • Torque Converter State
  • Turbo Speed (RPM) 1 & 2
  • Knock Energy (1-8)
  • RPM Rev limit
  • I Boost Position
  • Final A/F 1 & 2
  • Desired A/T Gear
  • Transmission Pressure
1 - 1 of 1 Posts
