1 - 4 of 4 Posts
Jihad Killer
I was just wondering what your guys boost controller setting are at for a low boost moode? The Gain % Set gain % ect?? I want 15lbs of boost!
The serach is down, i tryed..
Josh
Not so boring anymore
each car will be different.. its just kinda of trial and error..
start with the set at like 30% and work up from there.. I used like 15% gain on my friends honda.. held it pretty steady
Edit: oops mislabled set..
There are three control settings. "Set Boost", "Gain", and "Start Boost". Set Boost - increases boost from stock gate settings. Gain - Stabilizes boost. Start Boost - holds the wastegate shut creating quicker spool. I generally avoid using the Start Boost feature because it makes the turbo boost funny, when trying to control boost with the throttle (road racing). Use the "Set Boost" feature first, for the desired amount of boost and use the Gain feature to stabilize, if boost drops off at high rpm or creeps. With my T25, i had 15psi set up like Set Boost 50% and Gain 14-16%. With my 2871R, 15psi is Set Boost 40% and Gain 7-9%. Theres no need for the Gain to be up real high unless your trying to compensate for boosting problems.
1 - 4 of 4 Posts
