·What exactly does the Balance knob do on the Profec B? I have been told it reduces your lag when you put it on sharp, is this true?
Thanks, Dominic 91 Turbo
AFAIK if you spike ( that is over shoot your desired amount then you turn the balance knob counter clockwise mild. turning it up reduces spool and increase risk of a spike FWIW I have mine set at about 2 o'clock and the first setting at 3 = 15 psi 2nd setting inn 2 = 18 psi. works great no spike this is for TTC BTW.Dominic said:So sharp reduces lag and mild adds lag? Ive also heard it is used for spikes. Whats the real deal?
