Can the Profec display in PSI? the reason I ask.... makes it look like you can
Justin · Search Joined Dec 30, 2002 · 3,305 Posts Discussion Starter • #1 • Mar 27, 2005 Can the Profec display in PSI? the reason I ask.... makes it look like you can
A Alternet · Registered Joined Feb 8, 2003 · 234 Posts #2 • Mar 27, 2005 yes you can you have to click the main button (the round one) then rotate it or press the up or down arrows
QWIKSTRIKE · 475RWHP 449TQ and climing Joined Nov 14, 2002 · 5,941 Posts #3 • Mar 27, 2005 ^^^ just select psi when you high light unit select, Scrolll down to psi,
A adjuster · 25psi = 14" brakes :) Joined Dec 9, 2002 · 2,306 Posts #4 • Mar 27, 2005 I really like my Profec E-01 and Emanage setup. (easy to use, and about 600 less at the time than the EMS as my only other choice I was interested in.)
