No wife to complain about me spending too much money on a car. No more kids to pay for... Yep it's time to go stupid. This will be my first swap I have attempted. I do have some mechanical background but mostly it's remove and replace experience. I found a early 1989 turbo shell, no motor or transmission. I plan on doing a 2jzge NA build using the stock 7mgte ecu and wiring harness to start off with. Once I get the motor in and running, if I don't have to rebuild the motor after getting it running. I'll look into doing a mild NA-T build.
I've searched the forums for information and found a lot of dead links to pages or sites that do not exist. Also tons of replies telling the person to use the search button that leads to dead links and non existent sites.
This is what i have so far Project: Happily Divorced..
1989 MA71 body.
2jzge non=vvti from a 1997 SC300
Wiring harness from the 7mgte and grey plug 7mgte ecu.
Square mounts and adapters for the 2jz.
W58 transmission with 2jz bell housing
Stage 2 Comp Clutch
2jz flywheel
7mgte AFM
7mgte coil packs
7mgte CPS
7m oil pressure sensor
7m Temp sensor
7mgte injectors
7M IAC
7m Temp sensor
If I have forgotten anything please tell me. Other things needed for the swap:
12 pack Warsteiner Dunkel beer
12 year old Glenfiddich single malt Scotch
This post is getting long enough and people with ADD or ADHD just went
Squirrel!!!!!! Squirrel!!!!!! Squirrel!!!!!! LOOK AT THE SQUIRREL!!!!!
1989 MA71 body.
Stage 2 Comp Clutch
2jz flywheel
7mgte AFM
7mgte coil packs
7mgte CPS
7m Temp sensor
7mgte injectors
7M IAC
7m Temp sensor
