Would you happen to know of an N/A setup that should net 240whp? I'm just hoping it's possible. Money is of no concern, well within reason. $20,000 is too much lol
On stock?
Not happening. 20k (including machining, parts etc) is a START.
Going to be honest, i seen exactly one person attempt to do it and to say it was disappointing with the amount of money spent is an understatement. even with ITB (that has been a nightmare and know of only one person to get it going), just not enough RPM to do anything with it. MAYBE destroking the crank to get it to spin higher but now your adding even more cost. No matter how you cut it, it will cost a shit ton of cash.
The issue is that you will have to spin the living hell out of the NA since that is the only way to gain HP short off Nitrous, If you go the nitrous route, then you need the fueling, a controller etc. It will be cheaper initially but more expensive in the long term after recharging the nitrous that it would have been better to go turbo right out of the gates.
Also, that statement of "Money is no concern" is a contradiction.
I have seen more people say that more times than i care to remember and in the end, the project dies because of money. You will be surprised how EASY it is to burn through 20k on these cars and not achieve what you want.
