1 - 3 of 3 Posts
I'm just wondering what the correct pressures and temps should be so I can set my warning lights on my gauges.
Fuel pressure: What should I set my minimum to? What is the normal maximum under full boost?
Auto Tranny Temp: What should I set my max temp to? What is normal tranny temp ranges?
Thanks alot!!
Discussion Starter #2
Anyone?
Senior Member
My aeromotive fuel pressure regulator is set to 40 psi.
What fuel set-up are you running currently?
I am running twin in tank pumps. -10 SS feed line from tank y'd into dual feed -6 SS lines.
1 - 3 of 3 Posts
