1 - 1 of 1 Posts
Newbie
I tried the search but couldn't find anything for my questions? How long does it actually take for the ECU to fully relearn itself? What psi should I be running during this time? If I run at 12 psi for a month, and raise it to 18 psi after, will it run lean until I reset the ECU again since the fuel curve was meant for 12 psi? Is it okay to run xylene or an alcohol injection kit while it's relearning? Is there any steps you guys take after resetting the ECU?
Hope these questions aren't too stupid for the gurus to answer. I've always just wondered about the stock ECU.
Thanks.
1 - 1 of 1 Posts
