I just figured out that my leak is powersteering fluid from the pressure hose on the pump. The problem is that its not actually the banjo bolt that is loose; its the big hex that goes into the pump itself. And of course, I cant get to it without the pulley removed. I've got the pulley nut off so is there any way that I can get it off without a pulley remover. Is it even possible to get a remover in there with the stock fan in place?
