1 - 13 of 13 Posts
I just had by bl midpipe istalled this weekend and I must say it positively improved the car sound and performance. I now have a complete 3" exhaust system and it seems like that causes my pt52 to spool at 2500 rpm. It seems like once i hit the gas the turbo is ready to spool, I was wondering if anyone else is running a 3" exhaust system with a pt52 and their thoughts. My car is still untuned and running off of a .8 bar wg spring , hope to have it tuned in a few week and see what # the 52 is capable of.
looking for another Supra
the 52 is a 600 max flowing turbo and with the right fuel you can push it past 30 pounds of boost. i wouldnt go that high though. i am running 3 inch downpipe but my exhaust is 3.75 so i couldnt help you on that aspect. but it seems the turbo might hurt a little top end with size but you should be fine.
I am running a pt52 with a straight 3" exhaust, but I dont really have much to compare it to, its been that way since day one of turboing. Although my car has been having fuel mgmt issues for a while, I also notice it spooling around that rpm when i hit around 30-50% throttle or so. It seems like we may running somewhat of a similar setup, so once i sell my map ecu/vpc/afc and purchase/install the aem in the next couple of weeks, we can compare numbers.
.8 bar on an untuned NA-T is asking for trouble.
I've been running 5 psi(.35 bar) on a self-tuned NA-T for about 5 months and it's been fine, but the other day I turned it up to 8 psi(.55 bar) and I could immediately hear knock followed by powerloss(timing retard) at WOT.
As for the exhaust, I was running a 3" downpipe to the stock catalytic converter and then to dual 2" pipes.
It seemed fine (remember this is 5psi) until the cat blew and blocked exhaust flow pretty bad.
I then bought the BL midpipe and redid the back section in 2.5"
Now the exhaust sounds much meaner and I can feel a huge difference in topend.
Get that thing tuned!
Cheers,
~Alan
@turbolex.com
The PT52 holding 30lbs? hmm :tongue:
Is it turbo??
i have a pt52 and greddy evo exhaust and when i had my safcII i self tuned it and could hit 7.5 psi with no knocking at all! mine can hit full boost (7.5 psi) at 3200 rpms.
Built Auto
30 psi is possible on the 52, but way out of its efficiency range. I dont see anything past 25-26psi being efficient in terms of more power.
1 - 13 of 13 Posts
