1 - 12 of 12 Posts
Had some issues with the initial tune. Whoever setup the flexfuel tables didn't realize E-content scales as a decimal value(.6, .7, .8, etc), not as a percent on the AEM 712. So the boost never scaled and I've been on wastegate the whole time I've owned the car(<1yr) ??
I think the dip in the graph is the infamous AEM Infinity glitch/hole:cautious:
Anyway we got that sorted out and made a bit more steam. Keeping it at @20psi till the motor gets built next year.
Numbers seem a tad low(633/482 Dynojet SAE corrected), but it's a completely stock longblock so no complaints.
Boost Junkie
That's about right for stock cams. Nice job.
Steve
isn't 6870 around 633 on pump 93 ?? those E85 numbers are very low.
Yeh i'm not sure, I haven't seen any dynos of stock GTE motors with 93 or E85 @20ish psi.
With STD correction it would be ~650, it was also 95deg in the dyno room with texas humidity.
Looks like it would be a blast on the streets. Good job. What's your hp goals for the built motor?
thanks I love it, favorite part is how streetable and reliable its been! knock on wood
Probably ~800-850rwhp. I wanna keep it reliable/streetable. So full wet block, mild cams, pump e85, etc.
Might have a kill tune for 900-950 on VP Red only.
Sounds perfect. I just tuned my MKIII today and made 674 / 582 with a 6466. I was running out of injector or pump one at 7300 rpm. This was at 26.4 psi. I feel like 28 would have gotten me over the 700 mark or right at it. This is on e85 also. I guess it's back to the drawing board although 670 feels pretty good for the moment.
Turbine A/R ?
...pop the hood!
very nice
where in tx are you?
1 - 12 of 12 Posts
