1 - 9 of 9 Posts
Wingless Hardtop Moderator
My car has an abflug hood (ported) and its been rained on a couple times now.. and the pullys are starting to squeek... is it possible for the average person to change those? or does it require some mechanical skills?
While we're here can someone explain how easy(or hard) it is to replace the harmonic balancer? the outer-ring came off mine, and its only being held on by the pressure of the fan belt
King of the NA-T's
Bob: which pulleys are you refering to?
Supra93: You just need to take all the accesory belts off, impact the crank pulley bolt off, and use a puller to get the pulley off. Not too bad if you have those tools.
1 - 9 of 9 Posts
