1 - 20 of 20 Posts
This was on 93 octane pump gas with 18-19psi, but for some reason the boost would fall to about 16psi in third. I am very pleased with the results. I need to put the stock springs back on, get a real ET street, and my methanol kit back on and it should run on pretty well.
60' 1.804
330 4.951
1/8 7.507
MPH 96.19
1000 9.711
1/4 11.578
MPH 120.48
It felt like it was leaving harder than a 1.8 60', but that was the best I could muster. I ran five 11 second passes and two 12.0 passes, so it was fairly consistant. I quit after this pass eventhough I feel there is much more in it with the stock suspension on it.
2JZ S13
Very nice numbers!
this is the car that is for sale correct?
Discussion Starter #9
Well with the meth. injection on I turned it up slightly to 22psi. Anymore boost and it would blow out the spark. I am going to get an MSD box this weekend though. Here is the new best:
60'.....1.671
330....4.665
1/8.....7.160
MPH....98.37
1000....9.326
1/4.....11.170
MPH....121.93
8 Second 6spd
still on the distributor? did u try gapping plugs down more or running DLI?
SupraForums Manufacturer
60'.....1.671
330....4.665
1/8.....7.160
MPH....98.37
1000....9.326
1/4.....11.170
MPH....121.93
You shouldn't have any issues running 28psi with that ignition setup... if you do I would begin with new plugs gapped lower, coil, etc
yea you need to throw some race gas in there and run that turbo in it's efficiency range...boost it up to like 26pnds or so
EDIT: don't forget to get some spray for out of the hole! :-D
1 - 20 of 20 Posts
