1 - 7 of 7 Posts
Has anyone run this set up on a modified fender car? im concered about the height of the tire and whether it will rub on the launch
My car has extended fenders (about an inch wider) so i am not concerned about width...
i am on eibach springs (which can be removed in order for this setup to work)
please give me any experiences you guys have had, because im afraid the 28x11.5s wont cut it this year
(i know slicks would yield a better result on a smaller tire but i do not want a bias ply tire)
Thank You!
It will more than likely rub the factory side vent panel. My 28x11.5x16 rub if you have the car jacked up high enough, but once lowered back down its fine. When i mean by high enough, it really isn't that high.
its a slow auto...
Thank You!
an et street is a bias ply tire.. now if your taking about the 30" tall mt drag radials thats different, why not just run a 30x9 "radial" slick ? they make them for super stock cars...
well i was originally talking about the MT ET Street Radials... who makes the 30x9 radial slick? that would definitely fit
its a slow auto...
probably evey major drag tire company, since there used in super stock classes.. look on jegs.com they put and R next to it in the part number if its a radial design...
Discussion Starter #6
ahhh thanks i found em...
do you have n e experience using these? do they have still sidewalls? do they require i run front runners?
thanks
its a slow auto...
thanks
i've never used them , i might put them on my camaro when its done.. as far as front runners are concerned, I would'nt think so.. its a radial tire... and yes the side wall is stiffer then a bias ply tire..
1 - 7 of 7 Posts
