1 - 3 of 3 Posts
what did any of you do to help you get that damn IAC valve pipe clamp off of the driver side valve cover, it seems impossible to get to?
Also, there are 4 nuts total on both valve covers and 12 bolts which all(16) have locking washers?
Any difficulties trying to get those 4 nuts off? It seems like there also a tight fit to get to?
Any input appreciated.
Boost Junkie
Don't know on the IAC, it has been too long since my Supra had stock piping.
As far as the cam covers. Yes the 4 studs with the nuts and washers are a PITA. However, after you get the cam covers off, the best thing to do would be to remove those studs and replace them with 4 bolts-these bolts need to be slightly shorter then the other 12. This will make it much easier to reinstall the cam covers.
Steve K.
1 - 3 of 3 Posts
