1 - 3 of 3 Posts
I know the ciggerette lighter adapter shuts off power when the car is turned off,
is there a way to activate the relay that connects it to the battery when the car is off?
I want to use a trickle charger that I have (it has the ciggerette lighter adapter plug), instead of cutting and splicing to attach to the battery under the hood (actually trunk, it's been relocated)
rather do it this way too to keep the hood and trunk locked
thanks
Supra-NA-T...Girls -Twin
instead of having your cig lighter connectedto ignition, connect it to constant power (at the radio harness) and you should be good to go.
Yep. Plus that frees up the cig harness for an easy connection to whatever you need (if you dont re-use the harness and just run your own wires)
1 - 3 of 3 Posts
