1 - 1 of 1 Posts
It's only the beginning..
What the hell is a force line?
what is a "desired force line"
This is the procedure for the Antenna Rewire from the SOGI site
Procedure:
Disconnect the power antenna from the wiring harness.
Do not make any modifications to the factory wiring harness.
Make the modification on the antenna side of the harness.
Use a small screwdriver to remove the spade lug of the blue wire with light green stripe from the connector.
Cut off the spade lug.
Connect antenna wire to the desired force line.
Use a Scotch-Lock connector to splice the blue/green wire into the blue wire with the black stripe.
Reconnect the antenna connector to the factory wiring harness.
1 - 1 of 1 Posts
