·For the 93-98 TT:
Does Toyota currently sell the stock TT pads with shims attached? Or, do they intend for the SupraTT "shim-kit" to be used in addition to the metal backing already on the pad? Also, are the factory pads supposed to be installed with the pad-wear indicator on the lower side of the pad(closer to the ground)??
And last, in reference to the "fitment" kit (clips): When I am facing the caliper with the wheel removed, which side of the pad (left or right) does the clip fasten to??? I guess what Im asking is if someone can describe how the pads, clips, and shims are intended to be mounted? Hope I made sense...
Thank you in advance.
