1 - 8 of 8 Posts
Escaped from infinite lag
This is just simple im looking for people who are and have used a WB sensor setup to tell me if you leave your sensor in or take it out and plug it up? I heard that the sensors can go bad if you leave them in the exhaust stream for long periods of time?
thanks
wastegate hose is pulled
Most systems use the Bosch LSU 4.2. This sensor is an OEM application. It is permanately mounted in factory built cars with warrantys. Mine is permanately mounted, I'll be replacing it occasionally just like a normal O2 sensor.
modern wideband sensors are good for a long time, like chev said.
you cant leave the sensor in the exhaust if you are going to unplug it from your WB though.
boost freak
werd. look up the spex on your sensor. the bosch LSU sensor is rated for some obscene mileage on unleaded gas....and lots on leaded too....
Republican
Yep. Mine is permenently mounted too. they are so cheap now that replacing them is not a big deal anymore.
thanks guys ive been looking at the PLX M300 what is your personal opinion about his sensor
1 - 8 of 8 Posts
