1 - 2 of 2 Posts
Supralicious
Dusty,
IMO, the GReddy intake manifold seems to be promising. I have a question though. Are the factory provisions (throttle cable, cruise control brackets, etc.) externally mounted like the Titan one? Is it smooth or are there things that can disrupt the flow?
Hopefully they are not.
Rodrigo.
The Greddy, in terms of installation, should be compared to the Veilside / Virtual Works / Bullish more than the Titan.
Titan is a re-worked stock piece with limited flow. It is a true bolt-on installation. The Greddy, like the other mentioned IM's, is not a simple 100% bolt-on. You must relocate your battery and bolt on a Q45 TB at the very least.
The Greddy kit includes a new throttle cable.
If you are looking for a simple bolt-on with limited power then you want something that is based on the stock IM. If you want more power and the best flow then you will be relocating your battery.
Thanks,
Dusty
1 - 2 of 2 Posts
