I am going to purchase the panasonic CQ-C7301U from sound domain, installion kit is free but what i see is only the upper/lower half of the pocket or whatever
http://www.cardomain.com/sku/SCOTA2154B
im wondering if i need two of these? (one for receiver and another one for the bottom pocket)
stiles87 said:
you only need one. the head unit and that will make up the same space as the stock radio.
Like he said...you only need one pocket.
The head unit bolts into the top section of the Brackets..and the Pocket bolts into the lower section of the brackets. Or Vice Versa depending on how you want it positioned.
just got done installing something into a harness just like the one you are talking about and it works just as described above. although I didn't have any luck being able to put the pocket on top and the unit on bottom, the fit wasn't as good so I had to stick with the unit on top and pocket on bottom
