I read in another post that only Brembo's upgraded kits are true cast cross drilled rotors and all of the others (even brembo brand like MVP sells) is a Brembo rotor that is later drilled out. Is this true?
I'm asking because I need to replace my rotors and I'm wondering if I should just get the OEM. I will be doing some hot lapping at mid ohio and some regular autocrossing. I need something that isn't going to warp or crack, but I don't want to spend $3K for the Brembo upgrade.
