1 - 8 of 8 Posts
Curt, i need the following parts:
23300-49195 fuel filter $21.98
90311-46001 front main seal $10.57
90311-90006 rear main seal $30.47
13540-46030 timing belt tensioner $54.51
16620-46070 drive belt tensioner $169.11
...but before i order, i have a few questions.
1) is part # 16620-46070, the drive belt tensioner, a full assembly (pulley, bracket, shock, mounting hardware, etc)? or are there parts i need to order in addition to 16620-46070 to install it and make it work?
2) is part # 13540-46030, the timing belt tensioner, a full assembly? or are there parts i need to order in addition to 13540-46030 to install it and make it work?
...if there are additional parts to the two belt tensioners, could you please list their parts #'s and costs? and if not, could you verify the total cost (i came up with $286.64) on the list of parts at the top? i'd like to get this stuff ordered ASAP.
TIA,
Eric
Super Moderator
16620-46070 Tensioner List 221.49 Cost 169.11
16621-46010 Bracket,list 45.87 Cost 35.03
16622-46010 Arm, List 21.81 Cost 16.65
91511-g0845 Bolt, List 1.11 Cost .85 Ea X 2
90901-16001 Bolt, Stud List 2.46 Cost 1.88
90179-08171 Nut List 1.06 Cost .81 Ea X 2
90116-08348 Bolt, Stud List 1.00 Cost .76 Ea X 2
90080-17242 Nut, List 1.57 Cost 1.21 Ea X 2
13540-46030 Is Pre Assembled.
ok then, i need to order the following:
you can ship to:
Eric Asher
6343 Approach Rd.
Sarasota, FL 34238
i recently ordered some other things from you not too long ago. you can charge the same credit card i used last time i did business with you (assuming you still have my credit card info). if you don't have it, let me know and i'll email/call you with that info.
TIA,
Eric
1 - 8 of 8 Posts
