1 - 20 of 27 Posts
I know I need a plastic cleaner/scratch remover.
I heard Novus is good, but where on earth can I buy this instead of online?
Any other stuff I could use thats great which I can buy at a store and not online?
I would buy it online, but I need it no later than friday.
Wangan Nasty
If The interior of your headlight is dirty or messed up, you need to bake the light, pop it open and clean it, then re-seal it.
If it is just the exterior, what i do is (For plastic, oxidized, yellow w/e fucked up bad lights) is wet sand the light itself with 1500 or 2000 grit, then buff the whole light out with a PorterCable Random Orbit Buffer, a Yellow compounding pad and Autoglym Fine Abrasive Compound.
I cannot tell how many SC300, Supra, Rx7 etc headlights i have restored to 95% new using that combination.
If it was 2 weeks ago i could have helped you as i was in norcal for vacation, but i am back in so cal.
I'll be baking them tomorrow since the interior is bad. Autoglym Fine Abrasive Compound can be bought at any auto store?
Thanks for the info!
Wangan Nasty
Thats the hard part :ugh2: Its more of a speciality product, Autoglym is the detailing product lineup of jag and aston blah blah, and theres a store in so cal that sells it. But i can look around and see if there are places in Nor cal that sell it.
If not you can try a meguiars compound like 80 or 83? (not too familiar with them)
I recommend the SONUS SFX-1 pad from www.autopia-carcare.com to use with the Porter cable or if you have a good pad that will work too.
However, i do know the guys at the detail store here, and i talked to them. They do ship the stuff and do have a website i believe.
I throughly cleaned the inside of my headlight, then polished them with Novus. They have several different bottles going from rough grit to finer and you use them in sequence. I had very good results.
The only place I know you can buy it is it some plastic places that sell and cut plexiglass, or online. Use a cloth to polish.
Hayai Kuruma!
:rofl: be careful when u bakin them girl...
you DON'T wanna know what I did to my original stock headlights BEFORE i had to replace them with glass.... :rofl: :rofl:
rockin' the JDM duct tape
remove racks from oven
pre-heat to 350
remove metal clips, bulbs, wiring, etc from headlights
turn the oven off
insert rack
put the headlight in for about 10 minutes
*carefully* pry lense off headlight assembly
if it doesn't come off, let it warm up some more.
have you done it with a heat gun? were you able to heat it thoroughly enough?
I only heated my oven up to 190-200 degrees and it was enough to soften the sealant...not to say you shouldn't do it at 350. But if you feel safer with a lower temp, it will work fine.
^^^ good advice. i would do it with the lowest temperature that is hot enough to soften the sealant.
1 - 20 of 27 Posts
