1 - 9 of 9 Posts
RoastBeefCurtain Commando
Just curious. I asked this before and didn't really get any info on it.
On the tops of the injectors there is a bar that bolts across them. I guess to hold them in.
What is the deal with the o rings up top? Does that bar seal anything, or just helps hold the injectors in the rail?
I ask because I saw this pic the other day and I am having some breaking up problems and thinking about my injectors install now
Not so boring anymore
hmm...... interesting.. i havn't seen that, but after I put my injector back in from forgetting 1 of those bolts that hold it in it started to miss.....
really? Did your injectors fit snug against that retaining bar?
Maybe that is part of the reaston my car is breaking up?I had a slight gap.
I didn't look, but I lost 1 of the 3 bolts that hold that bar on or it backed out when driving or something, so an injector started to pop out (sprayed gas all over :( ), but when I fixed it I never checked to see if there was a gap. Im not sure if there was a gap to begin with iether, I never checked.
IM not spraying gas anywhere. I know that much. But I am curious as to if that tiny ass gap will cause enuff problems to push the injector out?
I also found cracks in all my coilpacks and replacing those this weekend. I guess thats the next thing to look at.
JZA is best f**k the rest
Mine didn't fit flush either, I think the whole purpose of the piece is to keep the injectors from popping out if it didn't seal correctly :dunno: Mine looked the same and sealed fine.
Jake
thanks.
Maybe Im lucky/unlucky enuff that its just the coil packs arching on my head causing my breaking up.
No.. If you look there are 2 bolts on the 123 injector holder rail peice thingy (lol) close together then one next to injector 1.. The bolt next to injector 1 was gone, i was trying 15 psi, 1/2 way through 3rd gear broke up so i got off of it.. I was 1/2 a mile from home, so just drove home.. got home turned the car off and heard a water like noise hitting the ground opened the hood gas was spraying everywhere (havn't wired up the fuel pump properly yet with the aem, so stays on 10-15 seconds after the car is off till main relay is switched off) , turns out boost pushed the injector out and bent the injector bracket peice.. ever since i put it back together it misses when i touch the gas, fine under boost and crusing.. just misses when i touch the gas.. when i put it back together i didn't check to see if there was a gap, and if that is a problem maybe why it missed, but i guess its probably not..
1 - 9 of 9 Posts
