i want the people who have put the na exhaust cam in their turbo motors opinion. should i do it while i have the engine apart now or should i just stick with the turbo cam?
PLEASE REPLY BACK SOON because im just about done with the motor and i need to know if i wanna do the upgrade or not asap. thanks guys
~nate
· Certified Supra Nut :P
well, you've oviously not searched this or you'd see the countless posts on this, and you obviously didn;t read any of them because if you had, then you'd know that the exhaust cams for NA and turbo engines are identical, it's the intake cams that are different.
----------------> /forum/images/red_search.gif
· Escaped from infinite lag
NA cams good for low end grunt ....... too much over 350hp and you get lots of blow through.
