1 - 4 of 4 Posts
Life is BOOST
Can the Cooland nipple pictured be rotated?
You should just eliminate the whole tb and isc valve coolant lines.
Life is BOOST
That has crossed my mind, since i am currently installing a RonR FFI. But since my FFI has the ISC installed in it, i want to have it fully operational. Correct me if I am wrong, doesn't the ISC use the coolant temperature to adjust the Idle during warm up/cold start?
no
ISC is controlled by the ECU and the ECU knows what the temp is by the water temp sensor located on the thermostat housing :)
You being in Miami can close that line up without issue ;)
1 - 4 of 4 Posts
