1 - 4 of 4 Posts
From what i found in the search this will fit in the rear but might not be the best offset. What i can't figure out is will this wheel need spacers to bring it out closer to the wheelwell or will it fit ok on it's own?
95 Hardtopper X 2
Should fit very flush without spacers and probably need fenders rolled if you go with 295's.
If you plan on running a 285, you will need to roll or cut your fenders. Im running a 10.5(+43) which means, the clearance from stut housing to the inside of the wheel will be 11mm MORE. The outside edge of the wheel will RETRACT in towards the body by 1mm compared to a 19x10(+38). I had to cut my fenders in order to keep from rubbing.
http://community.webshots.com/photo/305055083/1401773442053900082baqcKy
1 - 4 of 4 Posts
