1 - 20 of 22 Posts
Anyone still using a quick spool valve? The threads I’ve been searching are pretty old now and wanted to get an idea oh how many are still using them. Any drawbacks? I have a sp f1 manifold so it would be a 30 minute drop in for me.
No use to me now as I just realised that both my manifold and turbine exhaust housing is undivided
I know a lot of the SP guys are still using them. Larry doesnt come on the forums anymore but is still a big part of the community. They have made some crazy gains with spool valves.
Maybe try giving Larry at Sound Performance a call, he's always willing to answer questions and help.
Larry and his team are excellent and I do trust what they say. I’m just looking for feedback from members who current have a qsv and how it is day to day driving. Was it a pain to set and tune with it? Anyone notice elevated temps? Basically I know it works just looking If there are any cons.
iSPOOL
What turbo were you thinking of mating with the qsv?
I was about to go down to a new 6466 without it since I've seen how well it performs across the entire power.
Then I though about getting the 6766 or 6870 with a larger a/r and the qsv. Get the best of both worlds, quick response with a strong top end. Anything new would be a huge improvement over my old 67mm turbo lol.
But like you I wanted more feedback from people who have the setup. More along the lines of 3.0L, on pump, E85, and maybe a camshaft upgrade. I don't want to turn my Supra into a 1100rwhp lightning bolt, just something that can hold its against today's competition!
Discussion Starter #8
Turbo is bw s366 on a qsv ready sound performance f1 manifold with dual recirculated wastegates. Stock block vvti head and gsc s1 cams.
im also dnot want a 1000+ hp car.
Super Moderator
Dude, that's a fantastic combination for a no-BS street car, and it'll sound beautiful too!
Discussion Starter #10
thanks I love this set up. after my tuner was done he said this is the best combo he’s tuned. wanted to see if a qsv would optimize my set up
handy with the steel
This sounds like an absolutely awesome street car combo. Very similar to mine, except for the F1 manifold (which is an upgrade I'm considering). Surprised you can get away with the QSV and E85 on the stock bottom end, but man i bet the torque curve is THICC ... any dyno graphs?
EDIT: Nevermind, I see you don't currently have the QSV. I kind of wonder how much room for improvement below 4k you have that could be rectified with a QSV. My understanding of stock bottom end setups with E85 was that people tend to purposely run a larger turbo to delay boost onset so that you don't bend rods at low rpm.
Discussion Starter #14
lot of good points. I do run nitto drag radials full time in oem 17s but I also don’t want to have any more traction issues or worse case rod issues. I think I’m going to take biologist and t6rocket suggestion and leave it alone.
Boost Junkie
I can't recommend the QSV on the stock bottom end. Too much low end torque for those rods to handle.....you can tune it out, but then what's the point? Build the bottom end and use billet main caps and then run the QSV. They work great with high compression and VVTI.
Steve
i have one installed & it does it's job real well. Actually my tuner didn't believe it to start with?
/ Danny
I have the revised upgraded so qsv hd . But before u get excited I haven't installed it yet. I keep saying I will any weekend now. But the truth is. Since I am almost always driving my other vehicle during the weekdays, I only put about 20 miles per 4-5 months on my car lately. The set-up btw is just a 2nd gen GS. With the JDM 2jzgte Vvti, also running ECU and the Supra tt auto but with the oem rear end ratio, with stock twins, apu, 2stage nitrous etc, currently but I have everything I need to support and go ahead with my planned bw366 log Mani, QSV. Etc. However I have done tons of research prior to commiting to the mentioned setup. And there was more than enough evidence to prove for me it will be worth it. As the auto with oem torq conv, on the stock twins is to laggy for me when I drive it. I'm not shooting for 1200 hp. And it's going to stay a street car. But if there is still interest when I do the install, I'd be glad to give thorough detailed breakdown, and vids.
1 - 20 of 22 Posts
