C
Will 255/45ZR17 front and 275/40ZR17 back fit well with stock rims? Also I have no clue what the 45 and 40 stand for so any info is appreciated and if I got numbers wrong just let me know ASAP!
D u a l s t a r
Thoes numbers are the hight of the tire sidewall (in millimeters). It's how "thick" the tire is on top of the rim. So you have 17 inch rims and a sidewall hight of 40mm, would give you a wheel of 20.15 inches in diameter total on the back. (17 + 1.575*2) And 20.544 inches diameter in the front.
Re: Re: Quick tire size question
Actually the second number is the aspect ratio. This is a ratio of sidewall height to width. So a 255/40/17 has a sidewall that is 102mm tall, where a 275/40/17's sidewall is 110mm tall.
D u a l s t a r
Re: Re: Re: Quick tire size question
Ack! You are right. I wasn't thinking correctly.
