1 - 7 of 7 Posts
Car is a 93.5 Supra with a 6spd, V-160.
Anyways, my symptons are I can't engage into 1st gear at all, and 2nd as well unless I go crazy with the shifter.
I can get into 2nd if I put it in 4th, then 3rd, then 2nd. And I can get into 1st if I put it in 3rd, then 4th, then 1st. All done in less than one second.
Anyways, I want a quote on the parts circled in red. Dont know the names of any of them, so try your best to see what I am looking for.
Super Moderator
33511-14031 control shaft list 25.15 cost 18.60
33513-22030 yoke list 7.63 cost 5.65
90301-11015 o ring list 2.92 cost 2.15 x 4
33531-14010 boot list 39.44 cost 29.16
90387-08134 collar list 1.91 cost 1.41 x 2
90179-08095 nut list 1.14 cost .85 x 2
90105-08200 bolt list .89 cost .65 x 2
91651-60835 bolt list .26 cost .20 x 4
90105-08076 bolt list .74 cost .55
90179-08233 nut list .91 cost .68
90250-06026 pin list 1.06 cost .79
90467-21010 clip list 2.61 cost 1.93
33546-22020 bushing list 14.15 cost 10.47 ea x 2
Pretty sure what I need is called the control shaft. It is the metal rod that goes into the boot in the larger red circle.
I need that part. Just want to confirm before I order.
Is that the same bushing as 33575B in the pic? A pair of upper bushing on the shifter fork?
33575B (2)
33546-22020 LIST 14.63 COST 10.82 EA
Found the answer in another post. Looks like same part, just different numbers.
1 - 7 of 7 Posts
