1 - 8 of 8 Posts
Torturing a W58...
Need a quote on the following for my 5-speed 1995 SC300:
Exhaust Manifold Gaskets
Valve Cover Gaskets (need both sides, and the rubber plug on the top of the driver side valve cover - can post a pic of need be)
TRD Engine Mounts (do these work on the SC300? Found one of my OEM mounts was torn)
Flywheel bolts
Throw Out Bearing
Pilot Bearing
Master Cylinder (Clutch)
Slave Cylinder (Clutch)
Thank you!
17173-46020 GASKET, EXH LIST 17.96 COST 13.72 EA X 2
11213-46020 GASKET, VC 16.99 COST 12.98
11214-46011 GASKET, VC LIST 15.44 COST 11.79
90480-18001 GROMMET PVC LIST 5.03 COST 3.84
12315-46090 BRACKET,ENGINE LH LIST 120.21 COST 91.78
12311-46090 BRACKET,ENGINE RH LIST 135.44 COST 103.42
PTR04-00004 TRD ENGINe MT LIST 160.13 COST 121.03
90910-02103 BOLT FW LIST 7.89 COST 6.02 EA X 8
31230-22101 BEARING T/O LIST 70.16 COST 53.57
31410-14310 CYLINDER MASTER LIST 148.91 COST 113.70
31470-22120 CYLINDER SLAVE LIST 70.47 COST 53.81
90363-12002-77 BEARING, PILOT LIST 8.60 COST 6.57
Torturing a W58...
Thanks Curt! Forgot one thing - I need the gasket between the turbo oil-return line and the block (MKIV TT part).
Also, regarding the engine mounts, I see that you listed:
Do I need both brackets to use the TRD mounts, or are those the factory SC engine mounts and that price was just given so that I could compare it to the TRD price?
Torturing a W58...
Is the body of your stock mount approx 3 inches long?
If so :
12360-46111 INSULATOR 95.5-98 Supra NA/TT list 86.11 cost 65.75 ea x 2
12360-46111
Damn you're good - just beat me by a few minutes! Did some research on ClubLexus and those are the exact ones that were recommended. There's some GTE swapped guys pushing 800rwhp with these so I should be fine with these for now in my lowly 400rwhp NA-T.
I'll shoot an E-mail over after lunch to place my order. Thanks again for being so unbelievably responsive and helpful, Curt - you're the best!
1 - 8 of 8 Posts
